Frameboy
Dec 29, 2020Follower
Nighthawk XR500 behind another router / switch for Warzone
Okay...
I already have a fairly extensive network via Luxul (don't ask... it was here when I moved in) and it has a hefty router, a couple of smart POE switches and a Wireless controller with 4x AP's. I also have dual internet connections that my Luxul load balances.
So it isn't realistic to replace that with a Nightawk... However... can I get the GeoLocation feature if I go ISP Modem --> Luxul Router ---> Luxul Switch ---> Nighthawk XR500 --> My PC.
All I care about is the GeoLocation feature. My port forwarding and QOS is already done.
Thanks
1 Reply
- Netduma-FraserNetDuma PartnerInteresting setup! Absolutely, if all you care about is the Geo-Filter then it will work in that configuration.
