Evildaddy
Apr 30, 2020Aspirant
Nighthawk XR500 Blocking Adventure Academy
My Nighthawk XR500 is blocking Adventure Academy from connecting to the server. I was able to verify this by bypassing the router and connecting my PC directly to my modem and the game connected with...
Apr 30, 2020Guru - Experienced User
Evildaddy wrote:My Nighthawk XR500 is blocking Adventure Academy from connecting to the server. I was able to verify this by bypassing the router and connecting my PC directly to my modem and the game connected with no problem. How can I rectify this issue?
- EvildaddyApr 30, 2020Aspirant
The current firmware version for the Nighthawk XR500 is V2.3.2.56. I purchased the modem from amazon. It is a Netgear CM700. I doubt the modem has anything to do with the issue because when the PC was connected directly to the modem, bypassing the wireless router, I was able to play the game with no problem. I play MMOs and all types of other games with no issue. This is the only game I have experienced this problem with.
- Netduma-FraserApr 30, 2020NetDuma PartnerAre you using the Geo-Filter at all for the device? If so remove this, does that resolve it? Otherwise are you using Traffic Prioritization?
I dont believe geo-filtering is being used. When I navigate to the geo-filtering window there are no devices above the "Add Device" button. When I navigate to the QoS window, I have tried unchecking the All Devices -> DumaOS Classified Games check box, still no change.
- Netduma-FraserApr 30, 2020NetDuma PartnerCould you try disabling QoS fully in the Anti-Bufferbloat option menu please and see if there is a difference.
