Evildaddy
Apr 30, 2020Aspirant
Nighthawk XR500 Blocking Adventure Academy
My Nighthawk XR500 is blocking Adventure Academy from connecting to the server. I was able to verify this by bypassing the router and connecting my PC directly to my modem and the game connected with...
Apr 30, 2020Guru - Experienced User
Evildaddy wrote:My Nighthawk XR500 is blocking Adventure Academy from connecting to the server. I was able to verify this by bypassing the router and connecting my PC directly to my modem and the game connected with no problem. How can I rectify this issue?
Netduma-Fraser
Apr 30, 2020NetDuma Partner
Are you using the Geo-Filter at all for the device? If so remove this, does that resolve it? Otherwise are you using Traffic Prioritization?
- EvildaddyApr 30, 2020Aspirant
I dont believe geo-filtering is being used. When I navigate to the geo-filtering window there are no devices above the "Add Device" button. When I navigate to the QoS window, I have tried unchecking the All Devices -> DumaOS Classified Games check box, still no change.
- Netduma-FraserApr 30, 2020NetDuma PartnerCould you try disabling QoS fully in the Anti-Bufferbloat option menu please and see if there is a difference.
I have tried checking the disable QoS box, still no change.
