m-corse
Jun 09, 2018Aspirant
Nighthawk XR500 configuration for IPTV
Hi everyone
I have spent the last few days trying to get an HT500a IPTV set top box working with my new XR500 router but I'm not having much luck. I have configured VLAN tagging with a tag grou...
Ex0n
Aug 03, 2018Tutor
Hi, i have now been contacting netgear support lvl 3 to help me out with IPTV config in the XR500. I have also a big issue with this setup.
Due to i creat a VLAN tag group with internet set ID 10 and prio 0, the i know my Distrubtion VLAN ID TAG witch is 501 and prio 4.
even if i do this witch also show in the guid on netgear. My router can only process one of either package so why i apply this settings but internet shouts down and everything blinks orange as it dosent work but the IPTV is coming through which is so weird and i can watch the tv but everything els is out.
I have now run a debug log for lvl 3 support and send it to them and see if they can cript out what is going wrong.
But if nothing work i want netgear to take responsible and either send my money back or send a newer model which works with IPTV. But otherwise the internet connection is fantastic but the VLAN need to work.
Anyone els know whats the cause of this? Anyone solved this problem?
- Netduma-FraserAug 06, 2018NetDuma PartnerHave you heard anything from L3 support?
- Ex0nAug 16, 2018Tutor
Hi, im not sure what kind of support i have been given.
Because the problem still remains and i send log files of the VLAN and they try to figure it out.
I even contacted my ISP to secure if they might know whats the cause but they didnt either understand whats the issue.
They talked about IGMP Snooping wich i havent been using before. but i cant get it to work with that either.
Seems some software issue with the Netgear nighthawk XR500 is the issue.
But im not sure.
Anyone els got any idé how to solve this?
Kind R.
Christian Ulmered- Netduma-FraserAug 16, 2018NetDuma PartnerUsing VLAN and IGMP the issue still isn't resolved? I'd chase the ticket you have open
