Spaceflight102
Jun 17, 2020Tutor
Nighthawk XR500 Connection dropping frequently
Hello all, I currently have a Nighthawk XR500 router and my internet connection drops off randomly when using my laptop or apple TV but it drops maybe every 15-20 minutes when I am on my Xbox. I ...
Spaceflight102
Jun 18, 2020Tutor
My Setup is cable internert. I have a COAX cable > Hitron E31N2V1 Modem > XR500. All of the devices in my home are connected to the XR through Wifi. The problem happens with all devices including laptops, phones, etc. I have tried direct connecting to the XR and the problem continues. I tested my Xbox by plugging directly into the modem last night and everything ran perfectly, no connection issues over the span of 2-3 hours of playing.
Netduma-Fraser
Jun 18, 2020NetDuma Partner
Thanks for that information, when you see this happen can you still access the interface? If so go to System Information, what is the connection status? Also in Settings > Monitoring > Connection Status, what does it say for lease obtained/expires?
- Spaceflight102Jun 18, 2020Tutor
The status remains connected. Lease Obtained: 0 Days, 12 hours, 0 Minuets. Lease Expires: 0 Days, 9 Hours, 54 Minuets.
- Netduma-FraserJun 18, 2020NetDuma PartnerOkay so it is just the devices dropping internet then. If you give the devices reserved IPs in Settings > LAN do they sustain a connection when others disconnect?
I am currently at work so I will test this when I am off and will get back to you with the results. Thanks for the help so far.
