praljak
Feb 15, 2019Aspirant
Nighthawk xr500 connection issues
Hi all,
Purchased a XR500 router yesterday to replace my D-Link. I'm having issues setting it up wirelessly. When I try to connect wirelessly using my laptop it says it can't connect. The route...
praljak
Feb 16, 2019Aspirant
Thanks for the tips. Ended up being a static IP address. Changed that and all is good with the world đ
Netduma_Jack
Feb 19, 2019NetDuma Partner
Was going to say, sounds like static IP! Good job on finding the solution.
