Daltonb23
Mar 06, 2020Tutor
Nighthawk xr500 connectivity issues
I recently bought an xr500 router and for starters it worked good internet was fine now it’s very slow and causes problems to the point where it’s hard to play my PS4 if someone could help me get to a...
Daltonb23
Mar 07, 2020Tutor
I am paying for the max for my isp which is 60 but I only seem to be getting 30 mbs download and 2 mbs upload speed and yes I am using Ethernet to test and I never use wireless for gaming, and I am using Qos but it only seems to help ever so slightly
Netduma-Fraser
Mar 07, 2020NetDuma Partner
Have you input your expected speeds in Anti-Bufferbloats 3 line option menu? Are you using 'Always' and have lowered the percentages? If so then it is normal behaviour for the speed to be throttled. If you provide a screenshot I can let you know if it is working properly.
- Daltonb23Mar 07, 2020TutorI’ve tried messing with the bufferbloat but I never seemed to understand it well
- Netduma-FraserMar 07, 2020NetDuma PartnerThat explains why it was throttled then as you've not entered the speeds you pay for. I'd recommend you go through our optimal settings guide, it will help you get setup and to understand how the router works.
http://support.netduma.com/en/support/solutions/folders/16000090646- Daltonb23Mar 07, 2020TutorThanks I’ll try to see if that works
