Mikemike2177
Jan 20, 2021Aspirant
Nighthawk XR500 continues to randomly drop connections
So i have been searching and having this issue for days now both my wired and WiFi devices will randomly lose their connection to the XR500 i have already tested to make sure the problem is isolated t...
Netduma-Liam
Jan 20, 2021NetDuma Partner
Sorry to hear you're having trouble!
Do these drops occur in any kind of pattern? At a particular time perhaps?
Are you able to access the XRs interface when this happens?
If not, do you need to manually reboot the XR or will it come back up on its own?
- Mikemike2177Jan 20, 2021AspirantSo it happens all day and it’s more of a hiccup but enough to knocks my devices off line and then connect back up almost instantly but it def interrupts all activity connected to a spectrum provided modem
- Netduma-FraserJan 20, 2021NetDuma PartnerGo to Settings > Monitoring > Connection Status - what does DHCP obtained/expires say?
- plemansJan 20, 2021Guru - Experienced User
What spectrum modem is it?
What firmware is on the router?
If its happening several times a day, have you tried directly connecting a device to the modem and using it for a period of time to ensure it isn't a modem/line issue?
