EXE
Mar 01, 2018Initiate
Nighthawk XR500 Cooling
I previously owned an Asus RT-AC66U and it needed external fans to cool it as it could not passively cool itself sufficiently. Does the Nighthawk XR500 need external fans as well to cool it or is it r...
- Mar 01, 2018Hi EXE, I agree with Raptor's conclusion. Routers generally are designed to be 'always on' and so use little power. The XR500 has vents on the front, back and underside so as long there is nothing restricting the airflow in those locations then you should be fine to leave it as is.
crawlgsx
Mar 01, 2018Tutor
I also switched from an AC66U to the XR500.
I keep my XR500 behind glass doors in my entertainment center, whcih previously I could not with my AC66U.
I have had it in there for a few weeks and check it regurlarly, so far no issues at all :) (and it is in there with my smart home stuff, battery backup, switch, modem, etc).
I would definitely say heat is a non-issue for the XR500.
EXE
That's good to know! I definitely wasn't able to keep the Asus behind glass doors either but it sounds like the Nighthawk will be just fine in the open. Thank you for all the input and info! I will update this if anything changes!
