philter71
Mar 22, 2023Follower
Nighthawk XR500 create network folder greyed out
Trying to add a Seagate 6T Expansion desktop drive to router to create a network drive but even though all USB settings are on and all access methods are turned on the "create network folder" button ...
Mar 22, 2023Guru - Experienced User
Be sure the router is seeing the drive when it's connected.
What format is the drive using? I believe NTFS or exFAT are supported...
