Tylerball_
Jun 29, 2021Aspirant
Nighthawk xr500 disconnecting
Hello my netgear router for some reason keeps getting disconnected every like 10 mins, and I don't know why I have tried resetting to factory default, and that didn't work also my modem isn't having a...
- Jun 29, 2021Sorry to hear you're having this issue. What is the model of your modem that the XR is connected to? Does it disconnect all devices or just some and is it both wired and wireless devices?
Netduma-Fraser
Jun 29, 2021NetDuma Partner
Tylerball_
Not sure if my message sent so just incase I'm replying again. The model number of the modem is 100-04255 10 also the only thing that is hooked up wired is my xbox and I have 2 phones in the house and a roku that are on the wifi but thats about it
- Netduma-FraserJul 06, 2021NetDuma PartnerApologies for the late reply, it's only showing up now for some reason - is it a Gigahub? Does it have WiFi?
- Tylerball_Jul 06, 2021AspirantHey there no problem, and no my modem is not a combo router if thats what you mean? But actually I have not been dealing with connection issues since I have messaged you so I don't know what was going on. At first I thought it was broke but it's been working fine now.
- Netduma-FraserJul 06, 2021NetDuma PartnerOh well that's good to hear! Let us know if it happens again and we can delve deeper
