Retired_Member
Apr 19, 2018Nighthawk XR500 DNSMASQ
Is there a place in this router for DNSMASQ configuration? Or, maybe someone has other advice on how to get this to work. I setup a Raspberry Pi with PiHole, and the instructions seem to indicat...
Netduma_Jack
Apr 21, 2018NetDuma Partner
A user on the Netduma forum (where this is auto-posted) suggested this:
Within you lan dhcp scope set the dns for Lan devices to the Lan ip for your pihole device. That will forward all requests from Lan hosts to the pihole.
On your Wan up set dns to 4.2.2.1 and 8.8.8.8.
http://forum.netduma.com/topic/24713-nighthawk-xr500-dnsmasq/
Hope that helps.
