Subarumatt93
Nov 14, 2020Aspirant
Nighthawk XR500 dropping connections constantly after only 3 days
So I bought the Netgear Nighthawk XR500 after my 5 year old R7000 was broken during a domestic situation (it was still running strong) so I was given money to replace it. I ended up buying the XR500 a...
Netduma-Fraser
Nov 18, 2020NetDuma Partner
Sorry to hear about your home situation as well as the issues you're having. Yes there is an ongoing issue which sounds like what you have. Please try these suggestions:
Set a static/reserved IP for the XR in the ISP modem/router
Set static/reserved IPs for your devices in the XR LAN Settings
Do use the WiFi analyzer to find the least congested channels and change to those
Do wired devices disconnect also?
Subarumatt93
Dec 31, 2020Aspirant
I don't have a traditional modem as it's a fiber connection that goes directly into a powered plug and into my router. All my devices are wireless and as far as I can tell all drop connection for just a split second, but when it comes to gaming (selling point of the router) that's not really acceptable. I'll post results of my wifi anyalyzation. Mine is the one that starts with Corey's
- Netduma-FraserJan 01, 2021NetDuma PartnerOkay so the 5GHz is fine. Is it possible for you to connect via ethernet when gaming? If you have to play via WiFi then 2.4GHz would be better as it is more stable. Can you provide a screenshot for 2.4GHz as well?
