GrafixGuy
Nov 21, 2023Tutor
Nighthawk XR500 Dropping Internet
I have an XR500 that drops internet intermittently for no reason. It's running firmware v2 3.2.134 and says it's the most current update. I've dealt with my ISP multiple times and they would say all i...
Netduma-Fraser
Nov 21, 2023NetDuma Partner
In LAN Settings, set the DHCP range to start at .50, then assign reserved IP addresses to devices between .2 & .49 so they're out of the DHCP range, apply, reboot from the interface, wait 2 minutes and see if that stops the disconnects.
GrafixGuy
Nov 21, 2023Tutor
Thank you! I had already had .10 as the starting point as I only have two managed switches and two printers assigned in there thinking that the rest of my network could stay above that since I only have one computer I use reserved and another laptop I rarely use reserved above the .10 numbers. I do have a lot of smart home devices such as plugs, light bulbs, Ring doorbells and cameras, TVs as well as various other cameras. I reserved only two computers and let the rest assign itself. I will expand that up to .50 if you think that will make a difference or if you think it could be this I just discovered below...
UPDATE: Since posting this initial post, I found out I have a lot of DoS attacks. I contacted my ISP for a new IP address because renewing my DHCP lease used to reset and give me a new IP address years ago but it seems to not be that way now. They said I had to swap out my modem. Here's some of the attacks I'm getting. Don't know what else to do except swap out my modem. Any ideas? Thanks!
These are some of the attacks:
[DoS Attack: SYN/ACK Scan] from source: 51.38.116.208, port 25565, Tuesday, November 21, 2023 15:26:20
[DoS Attack: SYN/ACK Scan] from source: 103.233.161.238, port 8080, Tuesday, November 21, 2023 15:24:12
[DoS Attack: SYN/ACK Scan] from source: 103.233.161.238, port 8080, Tuesday, November 21, 2023 15:22:40
[DumaOS] DHCP new lease allocated., Tuesday, November 21, 2023 15:20:57
[DumaOS] DHCP new event., Tuesday, November 21, 2023 15:20:57
[DoS Attack: NULL Scan] from source: 182.18.90.86, port 14814, Tuesday, November 21, 2023 14:47:14
DoS Attack: ACK Scan] from source: 150.242.182.187, port 8080, Tuesday, November 21, 2023 14:31:06
- Netduma-FraserNov 21, 2023NetDuma PartnerI would highly recommend setting all devices connected a reserved IP address, it's precisely the auto allocation of IPs that I believe is the issue so reserving them should prevent the issue.
Netgear routers notoriously report DoS attacks when they're not a cause for concern and just show connections you've made/websites you've come in contact with. However, yours do show a lot of Asian IPs which I don't think you'd normally make contact with. They shouldn't cause you any issues at all, the router does have a firewall so they will be blocked. Unplugging your modem for 10 minutes may prompt a new IP- GrafixGuyNov 21, 2023Tutor
Ok. Thank you. I just have over 70 devices and not all of them list what they are so I will have to figure out what they are and label them properly an assign them an IP. Maybe that will let me track any funny business with some of these Chinese light bulbs and such. Thanks again!
Now if I can only figure out why my google mail settings aren't working to email me the logs. But that's another post.
- Netduma-FraserNov 21, 2023NetDuma PartnerThat is a bit of a mission to reserve them all but I do think it'll help. Ahh the light bulbs and such will probably be it then!
That's purely a Netgear feature so I'm not too sure about that, could be you need direct access to the internet so make sure the XR WAN IP is in the DMZ of your ISP modem/router and it should work then.
