OlRazzl3Dazzle
Dec 25, 2019Aspirant
Nighthawk XR500 Dropping Wired Internet Connection
Hello folks, I have been having issues with my Xbox One disconnecting from the internet just enough to kick me from the Destiny server, but not enough to kick me out of Xbox Live chat. My Xbox O...
Netduma-Fraser
Dec 26, 2019NetDuma Partner
Just to clarify, it's more that you're being booted from the game rather than the internet as no other devices are affected? Are you using the Geo-Filter and utilising the Destiny profile? If not you should do as an important option needs to be toggled - strict mode off and that should prevent you from getting kicked.
- OlRazzl3DazzleDec 31, 2019Aspirant
Netduma-Fraser wrote:
Just to clarify, it's more that you're being booted from the game rather than the internet as no other devices are affected? Are you using the Geo-Filter and utilising the Destiny profile? If not you should do as an important option needs to be toggled - strict mode off and that should prevent you from getting kicked.I am not using any sort of QoS tools in the NetDumaOS, and I am not using any sort of GeoFiltering.
As for what's happening when I get booted from Destiny, it states I have no internet connection but the lapse is so brief it seems to immediately begin working again.
I have also been having issues with Xbox Live Party Chat just randomly failing, and I am in a constant state of connecting, while everyone else is fine. So to answer your question, I think it has affected other devices but the lapse is so brief it doesn't seem noticeable unless you are utilizing services where a constant internet connection is required.
- Netduma_AlexJan 02, 2020NetDuma Partner
Could you use something like PingPlotter to keep an eye on your connection and see if you notice the connection dropping when the disconnections happen?
- OlRazzl3DazzleJan 02, 2020Aspirant
I have been using the program NetUptimeMonitor in order to monitor my connection, and I have been registering some disconnects. Usually, they happen in rapid succession for a particular period of time. The failures usually last somewhere between 5-6 seconds, but there was one logged for about 26 seconds. These may not seem like huge downtimes, but when playing games requiring a constant connection it can cause some very frustrating disconnects.
How can I rule out whether it is the router or my ISP that is causing the issue?
