blakec
Jul 24, 2019Aspirant
Nighthawk xr500 extremely slow connection help
I have a 400mbps download speed and the router initally sees this but as soon as setup is done it goes down to 65mbps wired. Even after I disable the QOS and anti blufferbloat it does not change. Plea...
Jul 24, 2019Guru - Experienced User
Netduma-Fraser
Jul 25, 2019NetDuma Partner
By disable you mean you've clicked disable QoS under Anti-Bufferbloat options? If so as it is a new router it may be taking some time to negotiate with your ISP correctly, this can take a few days. Alternatively you could give the XR500 the MAC address of the previous router you were using by entering it in the Internet Setup page and then reboot the router.
- blakecJul 25, 2019AspirantI've had this router for over a year now but just recently upgraded my internet
- FURRYe38Jul 25, 2019Guru - Experienced User
Has a full power OFF of the ISP Modem and XR router then back on with the modem and let it sync, then factory reset the XR router and walk thru the setup wizard?
blakec wrote:
I've had this router for over a year now but just recently upgraded my internet- Netduma-FraserJul 25, 2019NetDuma PartnerDid they provide you with a new modem? Did you adjust your speeds properly/have tried with turning of QoS using the method I mentioned?
- Netduma_AlexJul 26, 2019NetDuma Partner
Netduma-Fraser wrote:
By disable you mean you've clicked disable QoS under Anti-Bufferbloat options? If so as it is a new router it may be taking some time to negotiate with your ISP correctly, this can take a few days. Alternatively you could give the XR500 the MAC address of the previous router you were using by entering it in the Internet Setup page and then reboot the router.Try the above and let us know how it goes.
