I_AM_a_robot
Mar 16, 2025Aspirant
Nighthawk XR500 firmware or hardware issue?
My Nighthawk XR500 isn't working after a power outage--the device is protected by a UPS, but the UPS hibernated my computer and then powered off, so perhaps it took a hit. I tried to log into the ro...
Mar 17, 2025Guru - Experienced User
I've seen many users just hit the reset button. You have to push and hold for up to 15 seconds until the led changes (powered on). Did you try that?
What modem is it connected to?
What are the leds (all of them) doing on the router after the reset?
- I_AM_a_robotMar 17, 2025Aspirant
I've already held the reset button in for more than a minute multiple times. Nothing happens.
- FURRYe38Mar 17, 2025Guru - Experienced User
Try a 30-30-30 reset...
- Netduma-FraserMar 17, 2025NetDuma PartnerTry this TFTP method https://forum.netduma.com/topic/54949-dumaos-is-not-running/?do=findComment&comment=407569
