TimothyDo
Jul 28, 2019Aspirant
Nighthawk XR500 giving me lesser speed on my pc
On my computer im using wins10 and it doesnt give maximum speed (200mbps) and it seems that my iphone xs max also affected by it. Ive been using speedtest.net to test my speed but the highest was 157...
Netduma-Fraser
Jul 28, 2019NetDuma Partner
It sounds like those are the limiting factors. Follow this guide and see if Win10 gets full speeds after that: https://dottech.org/26628/how-to-force-windows-to-use-100-of-your-network-bandwidth-how-to-guide/ sounds like the android is newer than the iPhone as well which is why it gets higher speeds.
TimothyDo
The iphone got maximum speed once after the upgraded to 200 mbps but thats only for a day. And i got the full speed now after disabled the QoS. Not sure its safe to do that or not but at leadt now i got full speed...
- Netduma-FraserJul 28, 2019NetDuma PartnerOkay if you're getting full speeds after disabling QoS then that indicates your QoS settings may be dropping the speed which is normal in order to eliminate congestion. What settings did you have for QoS when it occurred?
- TimothyDoJul 28, 2019AspirantI just found out that the setting for the speed of my internet is set to be 157 no unknown reason. After changed it to 500, i got the maximum speed now. I put antibufferbloat to never, not sure if its better or bad....
- Netduma-FraserJul 28, 2019NetDuma PartnerOkay good, never means it's not active. We generally recommend 70% with always or when high priority traffic detected but it's up to you to decide what works best for you.
