ElijahA1's avatar
ElijahA1
Follower
Jul 30, 2020
Nighthawk XR500 keeps disconnecting from internet
My router keeps disconnecting from the internet every couple minutes. I barely set it up an hour ago and it's disconnected about 10 times. Everytime I would run a speed test it would disconnect during the test. Now it doesn't connect back to the internet.
1 Reply
  • First do a factory reset to regain internet access. What firmware version are you on? Go to Settings > Monitoring > Connection Status, what does it say for lease expired/obtained?
