Punchtown91
Jan 15, 2020Tutor
Nighthawk XR500 lag spikes
Hey Guys, I have the Nighthawk XR500 and lately I have been having very high lag spikes and the only thing that temporarily fixes the problem is by factory resetting the router. The problem it is t...
Netduma_Alex
Jan 16, 2020NetDuma Partner
Sorry to hear you're having these issues.
Next time a lag spike occurs, could you go to the System Information page and see if the CPU usage is high?
Punchtown91
Jan 17, 2020Tutor
Here is a screen shot of my current ping times.
- Netduma-FraserJan 21, 2020NetDuma PartnerAre you using QoS at all? Are ALL devices connected to the router? Also doing those kind of tests would be better on wired devices as wifi can be less reliable.
