joanz7s
Dec 13, 2021Aspirant
Nighthawk xr500 ping spikes when in router mode
Ever since I got this router I felt a difference in my ping when playing LOL as it went higher and unstable ranging between 70 and 80 ms with ping spikes up to 130 ms. I tried several things like reb...
Dec 13, 2021Guru - Experienced User
What router are you using when you put the XR in AP mode?
Are you pinging with a wired connection?
Have you pings with just a wired PC connected to the modem only? Use Pingplotter.com as a test app.
Has a factory reset been performed and setup from scratch since last update and left sliders at 99% and QoS disabled?
- joanz7sDec 13, 2021Aspirant
V2.3.2.130
Just the CM1000 modem connected to the XR500 connected to the pc with an ethernet cable
Yes
Yes and that solves the issue
I tried to but the software is so buggy that I dont even know if I did it correctly, what sliders are you refering to?.
- FURRYe38Dec 13, 2021Guru - Experienced User
There should be two long slider bar lines in QOS that have upload and download. One is red the other is blue. Little round ball button on the line. You can move this button to the right or left. You can enter in a value like 99 in the box seen to the far right I believe.
- Netduma-FraserDec 14, 2021NetDuma PartnerWhat QoS settings have you set exactly? There is more to it than being activated so it's very likely you need to fine tune QoS.
- joanz7sDec 15, 2021Aspirant
I have congestion control always enabled with both bars at 100% and bandwitdth allocation 80% to my desktop and 5% to all the other devices on both download and upload with traffic prioritization disabled.
