pullsouthair101
Apr 10, 2020Aspirant
Nighthawk XR500 slow output
My new nighthawk XR500 router only puts out about 100Mbps wifi and LAN. When i hook my PC directly to my modem i get downloads speed at 505Mbps When i hooked up the router and did the setup rout...
Netduma-Fraser
Apr 14, 2020NetDuma Partner
Have you changed any QoS settings? If you disable QoS completely from the Anti-Bufferbloat option menu does that help?
- pullsouthair101Apr 15, 2020Aspirant
I had to do a second factory reset for some reason (on a brand new unit) and now it is working fine.
- Netduma-FraserApr 15, 2020NetDuma PartnerOkay well keep us updated, hopefully it doesn't happen again.
