Sand323
Oct 30, 2023Guide
Nighthawk XR500 slow upload
Hi guys, spectrum around my area just got upgraded to 1 gig and since the upgrade my router just went to crap. My download got better but my upload won’t exceed pass 2 can anyone help?? I’ve already ...
- Nov 01, 2023
Glad they got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
Sand323
Oct 31, 2023Guide
Yes, I put the new speeds into the bandwidth and have been testing the speeds through the router log in for the dumaOS
Netduma-Fraser
Oct 31, 2023NetDuma Partner
Test on speedtest.net, what speeds do you get?
- Sand323Oct 31, 2023GuideI get 340 down and 2 up
- Netduma-FraserOct 31, 2023NetDuma PartnerCould you attach a picture of your QoS page please?
- Sand323Oct 31, 2023GuideSpectrum maintenance crew has been out here for a couple hours already and ended up fixing whatever was wrong.
My XR500 is back to running at optimum levels.
Thanks for the help, really appreciate it.
