FrankieJ54
Dec 04, 2018Aspirant
Nighthawk XR500 slow wifi speeds
My setup: Comcast GB internet> CM1000 > XR500>EX8000 So here’s my issue, when connected directly to Ethernet I’m pulling about 480Mbs down and 40 up. When connected to WiFi with QOS off I’m pulling...
Netduma_Jack
Dec 19, 2018NetDuma Partner
The fact you're at 100mbps suggests you're using a CAT5 cable somewhere in your setup e.g. between the router and the modem. Do you have a CAT5e or CAT6 cable you can use instead?
Websurfer33
Feb 05, 2019Aspirant
Did you ever get this working.
Im having the same issues .
I have fiber 200/200 Mb when plugged direct i get full speeds while connected to wifi i get max 25mb Up and down on the 2G and even slower 15Mb on the 5G .
I have disabled QoS no geo filter tried reset new firmware
Nothing seems to fix this.
- FURRYe38Feb 06, 2019Guru - Experienced User
What FW is currently loaded?
What is the Mfr and model# of the ISP modem the NG router is connected too?What devices are you testing with?
Are wired speeds good with a PC?
What WPA security modes are you using?Try enabling Beamforming and MIMO.
- FrankieJ54Feb 06, 2019AspirantThe only solution that fixed it for me was unfortunately an exchange for another unit. Now I’m averaging much higher and consistent speeds.
- Netduma-FraserFeb 06, 2019NetDuma Partnerweb, do you get your full speeds via ethernet to the XR500?
