BrodieStorch
Feb 01, 2021Aspirant
Nighthawk XR500 slow wired connections
I have the lastest firmware on the xr500. I'm getting laughable wired connection download speeds(10mb) (Upload speed is fine 22mb). I tested 2 cat6 cables and mulitple ports. I also confirmed it was ...
Feb 01, 2021Guru - Experienced User
Have you went into the qos settings and manually set it for your speeds?
