crj83
May 02, 2019Aspirant
nighthawk xr500 speed help
Hello i have the nighthawk xr500 with virgin 320mb internet and i am struggling to get the speed on my laptop and other devices ont the laptop i am getting between 30 100 mb same on the iphone 5. I d...
Netduma-Fraser
May 02, 2019NetDuma Partner
Sounds like plemans is correct in that the dell is the one device experiencing the issue. You may need to update the network drivers/adapters on the dell.
crj83
It's not just the dell it's the iphone 5 and two differant iphone x all slow speeds
- Netduma-FraserMay 02, 2019NetDuma PartnerSo just wireless devices then? Use a WiFi analyser to find the least congested channel in your area and then change to that.
- plemansMay 02, 2019Guru - Experienced User
Also list what speeds you are getting on them, what distance from the router you were, and 2.4ghz or 5ghz speeds. This helps. Try the scanner as prior suggested.
