t0ny's avatar
t0ny
Apprentice
Aug 05, 2019
Nighthawk XR500 USB Control Center not recognizing my printer AGAIN
Hey guys, this issue came back few days again. Same issue, the printer is not seen in the USB Control center. The light on the router blinks white. If I connect a Flash drive it doesn't blink, it sta...
  • Netduma-Fraser's avatar
    Aug 07, 2019
    Would you be able to roll back the Windows PC to previous updates and see if it works then?
