t0ny
Mar 21, 2018Apprentice
Nighthawk XR500 USB Control Center not recognizing my printer
Router : Nighthawk XR500 OS : Windows 10 Printer : Samsung ML-2165 I tested the USB ports and they recognize the Flash drive and the USB light is on on the front of the router. I unplug the dr...
t0ny
Aug 02, 2018Apprentice
4 months have passed and still no printer support.
Netduma-Fraser
Aug 02, 2018NetDuma Partner
Did you call Netgear as advised previously and have you upgraded to the latest version of the XR500?
- t0nyAug 02, 2018Apprentice
Yes, I called, they called, we had long conversations and I sent them logs and it was concluded that this will be addressed in the new firmware. Well, I am on the latest firmware and nothing is changed.
- Netduma-FraserAug 02, 2018NetDuma PartnerWhat is your support case number? I will escalate it.
Case #00298486
In the meantime I found this https://community.netgear.com/t5/Nighthawk-WiFi-Routers/Printer-is-not-seen-since-firmware-update-V1-0-5-48-1-1-79/m-p/1014727#M22371
Where is the ACL in Duma OS so I could try their suggestion?
But then again, I don't even see a ReadyShare Printer option in the USB Storage menu, just Media Server, ReadyShare Storage, ReadyShare Vault and USB settings.
