t0ny
Mar 21, 2018Apprentice
Nighthawk XR500 USB Control Center not recognizing my printer
Router : Nighthawk XR500 OS : Windows 10 Printer : Samsung ML-2165 I tested the USB ports and they recognize the Flash drive and the USB light is on on the front of the router. I unplug the dr...
t0ny
Aug 02, 2018Apprentice
Yes, I called, they called, we had long conversations and I sent them logs and it was concluded that this will be addressed in the new firmware. Well, I am on the latest firmware and nothing is changed.
Netduma-Fraser
Aug 02, 2018NetDuma Partner
What is your support case number? I will escalate it.
- t0nyAug 02, 2018Apprentice
Case #00298486
In the meantime I found this https://community.netgear.com/t5/Nighthawk-WiFi-Routers/Printer-is-not-seen-since-firmware-update-V1-0-5-48-1-1-79/m-p/1014727#M22371
Where is the ACL in Duma OS so I could try their suggestion?
But then again, I don't even see a ReadyShare Printer option in the USB Storage menu, just Media Server, ReadyShare Storage, ReadyShare Vault and USB settings.
The last sensible reply from them was:
"We are still waiting for the next official Firmware release to fix issue with the readyshare print function of the router. There is not ETA yet but engineering is aware about this and fix will be added on the next Firmware release."
- Netduma-FraserAug 02, 2018NetDuma PartnerI've sent you a PM, please see if its fixed the version I've given you. If not I can escalate.
That feature was removed by NG due to some issues.- t0nyAug 02, 2018Apprentice
Thank you , I can see the option now. :-) Now when I open the NETGEAR USB control center app I can see the XR500 which is good as I couldn't see it before and even the USB light is on now - success :-) But the XR500 listed in the USB control center is in red and you can't see the printer there. I will try few restarts and reboots and another printer later on and will let you know. Thank you.
