DJdubstep
Jan 01, 2019Aspirant
Nighthawk XR500 will connect with devices, but it will not connect to internet!
I recently got a new Nighthawk XR500 router. We did all the new user setups, and it said all the firmware was up to date. But, when we try to connect a computer or device to it, it says there is no in...
Roadster_Man
According to many accounts, this is no surprise.
It's been an issues for several models coming up to this one. It also happens follows their severely out dated GUI. I'm discussed by my 7600 as well for the same issue. It just doesn't go away. Netgear seemingly refuses to fix this issue.
Roadster_Man
Jan 02, 2019Aspirant
Same problems with R7500
- Netduma_JackJan 02, 2019NetDuma Partner
This is incredibly rare to happen on the XR500.
DJdubstep - do you know if your connection uses PPPoE (where you use a username and password to get online)?
If you haven't already, try rebooting your modem, then rebooting the XR500, and see if that then connects.
Worst case, give official NETGEAR support a call. They are very experienced at troubleshooting this initial Internet setup: https://www.netgear.com/support/contact.aspx
- DJdubstepJan 02, 2019AspirantI just found out that my isp does not use a PPPoE, but I also read something that I may need to release the dhcp of the old router, and give the new router access. Do you have any tips or ideas? I think this may be the issue, and I will report if this is successful.
- Netduma_JackJan 03, 2019NetDuma Partner
That's something you would need to do on your modem. Do you know the make and model? Worst case just factory reset the modem (if it has the option to!)
