Thonie
Oct 02, 2019Initiate
Nighthawk XR500 Wired Slow Speed
I just bought a Nighthawk XR500 based on the positive reviews online. I don't want to be an early adopter of Wifi 6. Anyhow, I'm subscribed to Gigabit from my Canadian ISP (Rogers) and my old router...
- Oct 03, 2019
After so many frustrating days, I've finally resolved the issue.
The XR500 was able to capture 932 Mbps during the initial setup. So, I thought the QOS is somewhat limiting the output. I bought a 50 ft cable and hook it up to the router directly to the PC. Boom! DL started showing 880 Mbps & 32 Mbps UL. I removed the long cable & put back the old ones.
I started tracing my cables & swapping cables, nothing change...same slow speed.
The solution was powering off the ethernet switch. Lo & behold...my speed went back to close to gigabit speed.
BTW, I lived in a 3 story house so, there's a 5 port switch on each level.
I would like to thank both of you for responding to my initial post. I was about to go crazy trying to resolve the slow speed issue. The forum is a good source for troubleshooting. I wish that I came here immediately at the first sign of trouble instead of wasting my time reading the manual.
Netduma_Alex
Oct 03, 2019NetDuma Partner
Sorry you're experiencing issues!
So are you saying that the speed issues persisted even after you ticked Disable QoS? If so, that rules out QoS as the cause of the problem.
The confusing element here is that Wireless is faster than Ethernet. I wonder if the wireless is what's limiting that max speed, or if the total throughput arriving to the router is lower than expected.
When you first started the router and it did a speed test, what were the suggested values?
