Thonie
Oct 02, 2019Initiate
Nighthawk XR500 Wired Slow Speed
I just bought a Nighthawk XR500 based on the positive reviews online. I don't want to be an early adopter of Wifi 6. Anyhow, I'm subscribed to Gigabit from my Canadian ISP (Rogers) and my old router...
- Oct 03, 2019
After so many frustrating days, I've finally resolved the issue.
The XR500 was able to capture 932 Mbps during the initial setup. So, I thought the QOS is somewhat limiting the output. I bought a 50 ft cable and hook it up to the router directly to the PC. Boom! DL started showing 880 Mbps & 32 Mbps UL. I removed the long cable & put back the old ones.
I started tracing my cables & swapping cables, nothing change...same slow speed.
The solution was powering off the ethernet switch. Lo & behold...my speed went back to close to gigabit speed.
BTW, I lived in a 3 story house so, there's a 5 port switch on each level.
I would like to thank both of you for responding to my initial post. I was about to go crazy trying to resolve the slow speed issue. The forum is a good source for troubleshooting. I wish that I came here immediately at the first sign of trouble instead of wasting my time reading the manual.
Oct 03, 2019Guru - Experienced User
Are wired speed test to spec at the ISP modem directly?
Thonie wrote:I just bought a Nighthawk XR500 based on the positive reviews online. I don't want to be an early adopter of Wifi 6.
Anyhow, I'm subscribed to Gigabit from my Canadian ISP (Rogers) and my old router is averaging 700-800 Mbps DL speed.
Somehow, when I connected the XR500 (wired), I'm only getting 72 Mbps (DL) & 24 Mbps (UL).
Wireless: 238 DL and 27 UL.
Before I posted this, I went over similar speed issues & followed the suggested changes.
- On Anti-Bufferbloat, set the mode to 'Never'
- On Bandwidth Allocation (also on the QoS page), click Reset Distribution on both the Download and Upload options
- On Bandwidth Allocation, open the Options menu using the Burger icon, and make sure 'Share Excess' is checked. You will need to do this on both the Download and Upload options
- In Traffic Prioritization, remove any manual rules you added.
Last step was disabling QoS' option. Nothing works! It's frustrating.
By the way, my router has a Firmware V2.3.2.56. My PC has Win 10.
I hope someone could help me out with this. If I cannot resolve the speed issues, I have to return it to the store.
Thanks.
