Vanthedia
Dec 19, 2022Guide
Nighthawk XR500 Won’t Factory Reset
Hello, Last night I decided to update my Nighthawk XR500 Gaming Router firmware, while two minutes into the process, internet from the ISP side dropped and stayed out for ~12 hours. Now my router ...
- Dec 19, 2022
As soon as you sent this I have figured it out.
The steps had me enter and select "cd desktop" and I am such a numb-skull that I had it stored in a folder on the desktop instead of the actual image on the desktop.
Once I put the image on the desktop it was successful and I am now up and working.Thank you everyone who contributed to helping me today!
Netduma-Fraser
Dec 19, 2022NetDuma Partner
If you're getting this error: TFTP can't read from local file then it means that the full file path hasn't been given, once you've done that it should take it
Vanthedia
Dec 19, 2022Guide
- plemansDec 20, 2022Guru - Experienced User
Glad it was a simple fix!
I'd make a backup in case you have to reflash it and restore it again
- michaelkenwardDec 20, 2022Guru - Experienced User
Always a good idea:
