Dlucas78
Nov 25, 2018Aspirant
Nighthawk XR500
I have purchased and upgraded my home router to the AC2600. I have also upgraded my 1GB internet. However when I have my computer plugged directly into the router. My speed never will go to above...
Nov 25, 2018Guru - Experienced User
What FW is currently loaded?
Do a reset on the XR router and walk thru the setup wizard. When it gets to the detected internet speed. Let us know what it detects here.
You can also manually input speed settings 1000/1000 I believe under QoS...
Dlucas78
Nighthawk current Firmware 2.3.2.32
ISP Modem Netgear CM-1000-1AZNAS
DOCSIS 3.1 21X8
- Dlucas78Nov 25, 2018Aspirant
When it goes through the setup and dectects the speed I get 300/300 which it is suppose to be 1 GPS up and 1 GPS down.
- FURRYe38Nov 25, 2018Guru - Experienced User
What happens if you manully input 1000/1000?
Something you need to contact NG support about.
- Dlucas78Nov 25, 2018AspirantI have spoke to netgear support for 3 times. They keep telling me to call my ISP. My ISP tells me to call netgear. When I change it to 1000/1000. My router slows network to a crawl
