ETSxbl
Jun 11, 2019Aspirant
Nighthawk xr500
Hello, i recently got the nighthawk xr500 when i connected it i got 20 ping now I’ve been using it for a couple days and now my ping is sitting on 50-60 is there a way to lower this
ETSxbl
Jun 19, 2019Aspirant
It’s my ping it’s now a 60-70 and i have the best wifi where i live but it’s still high. I pinged the server near me
ETSxbl
It is my ingame ping
- Netduma-FraserJun 19, 2019NetDuma PartnerWhat game are you playing? So you're going off the ping it shows in game and not the Geo-Filter ping? Are you using the Geo-Filter or QoS? I would recommend you go through the optimal settings guide to make sure you're set up properly: http://support.netduma.com/en/support/solutions/folders/16000090646
- ETSxblJun 19, 2019AspirantThe game I’m playing is fortnite and i use both QoS and Geo Filter
- Netduma-FraserJun 19, 2019NetDuma PartnerWhere are you located and what server are you getting?
