HelppMee
Jul 30, 2019Aspirant
Nighthawk xr500
I keep getting Moderate Double NAT Detected on my Xbox. I can’t put my Xfinity Modem In bridge mode because I need the wireless internet. And I can’t put my Nighthawk XR500 in AP mode because if I do ...
Jul 31, 2019Guru - Experienced User
Modem Combo Units:
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the NG router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ/ExposedHost or IP Pass-Through for the IP address the NG router gets from the modem.
Try #2 with the ISP modem in Router mode...
HelppMee wrote:
I keep getting Moderate Double NAT Detected on my Xbox. I can’t put my Xfinity Modem In bridge mode because I need the wireless internet. And I can’t put my Nighthawk XR500 in AP mode because if I do that basically disabled all the features like GEO Filter Qos and everything so I chat do either of those I need help on how to open my nat.
