HelppMee
Jul 30, 2019Aspirant
Nighthawk xr500
I keep getting Moderate Double NAT Detected on my Xbox. I can’t put my Xfinity Modem In bridge mode because I need the wireless internet. And I can’t put my Nighthawk XR500 in AP mode because if I do ...
HelppMee
Jul 31, 2019Aspirant
This is what comes up what do I do.
Netduma_Alex
Jul 31, 2019NetDuma Partner
You're trying to configure the DMZ on the XR500 but you should be trying to configure it in your modem's interface instead!
Go to system information in DumaOS and write down your WAN IP, and then put this into the DMZ of your modem.
- HelppMeeJul 31, 2019Aspirant
It has no last number
Ok I got the WAN IP
Is this what it should look like
- FURRYe38Jul 31, 2019Guru - Experienced User
Is that the IP address the XR is getting on it's WAN port from the modem? if so, then this should work.
it still gives me double nat
- Netduma_AlexJul 31, 2019NetDuma Partner
You didn't need to write anything in the IPv6 fields, but essentially yes that's right!
Do I have to do anything in the xbox settings?
