tonks1982
May 10, 2020Aspirant
Nighthawk XR500
When I play Call of Duty multiplayer my bullets connect, I do experience lag but its minimum like all players experience. But, when I play Call of Duty's Warzone I experience non stop lag. Bullet...
Netduma-Fraser
May 12, 2020NetDuma Partner
What is the average ping to the game as shown by the Geo-Filter? Are you using QoS? If so what settings are you using?
tonks1982
May 13, 2020Aspirant
Geo Filter is set to UK and 3000km but auto ping says "There is currently no host or server to ping"
QOS
Anti-Bufferbloat is set to "when high priorty traffic detected"
Download / Upload I've changed a few times between 70 and 80 %.
I've added my games console in traffic prioritisation.
Share excess bandwidth is ticked.
- Netduma-FraserMay 13, 2020NetDuma PartnerThat is quite a big radius, especially given the abundance of servers in Europe. I would suggest you change that to 1000km which will give you close servers and hopefully resolve the issue you're having. What platform are you playing the game on?
- tonks1982May 13, 2020Aspirant
Playstation 4
Surely the distance shouldnt be causing the amount of issues im having in every single warzone game?
- Netduma-FraserMay 13, 2020NetDuma PartnerIt really depends which servers you're being connected to - with 3000km you're almost reaching the middle east. If servers aren't appearing try this:
Remove console from the Geo-Filter
Hard turn off the console
In Geo-Filter Map settings flush the cloud
Re-add the console to the Geo-Filter
Adjust your settings
Boot the console and game
