AdamL0309
May 25, 2020Aspirant
Nighthawk XR500
Hi, I recently purchased this Router as I’m a serious gamer and loved the look of it, however I didn’t realise it couldnt just be plugged in and used as it has no built in Modem?? I am currently with ...
AdamL0309
May 26, 2020Aspirant
So I’m connecting it to the Plusnet HUB 1, I’ve just got off of the phone to the ISP and they said they’re router (HUB 1) doesn’t support “bridge mode” the guy didn’t seem to sure but he said maybe to purchase a modem called the DM200? Back to square 1 im confused..
May 26, 2020Guru - Experienced User
potentially the plusnet device has a dmz built it.
Set the dmz in it to the nighthawks ip address.
- AdamL0309May 26, 2020AspirantWhere do I have to do that? Sorry for being stupid lol
- plemansMay 26, 2020Guru - Experienced UserStart in the user manual for the plusnet device. you still haven't put model number but find the manual for it and look up putting a device into the dmz.
- Netduma-FraserMay 26, 2020NetDuma PartnerAs above, there is no need to buy a new modem when the DMZ should be sufficient. If it doesn't have a DMZ option then you can port forward 1-65535 TCP/UDP to the router and it will have essentially the same outcome. Also disable WiFi on the hub.
