AdamL0309
May 25, 2020Aspirant
Nighthawk XR500
Hi, I recently purchased this Router as I’m a serious gamer and loved the look of it, however I didn’t realise it couldnt just be plugged in and used as it has no built in Modem?? I am currently with ...
May 26, 2020Guru - Experienced User
Start in the user manual for the plusnet device. you still haven't put model number but find the manual for it and look up putting a device into the dmz.
Netduma-Fraser
May 26, 2020NetDuma Partner
As above, there is no need to buy a new modem when the DMZ should be sufficient. If it doesn't have a DMZ option then you can port forward 1-65535 TCP/UDP to the router and it will have essentially the same outcome. Also disable WiFi on the hub.
