AL221
Nov 28, 2020Aspirant
Nighthawk XR500
I just got the new Xbox series X, and my console was having trouble downloading content. I am using a wired connection that’s connecting to 1st wired port on the router. When I went to the VLAN/Bridge...
Netduma-Fraser
Nov 29, 2020NetDuma Partner
Do you know if you actually require VLAN? I would be very surprised if you didn't and that cause it to work. What is your exact physical setup?
AL221
Dec 07, 2020Aspirant
Thanks for replying! I honestly have no idea if I require it. Honestly don’t even know what that means, lol, I’m not very good with this router stuff. By my physical setup do you mean how my router is setup?
- Netduma-FraserDec 07, 2020NetDuma PartnerOkay so you probably don't need it then, no idea how that worked. Yes how is the XR connected to the internet e.g. through an ONT, ISP modem/router etc and how your devices are connected.
- AL221Dec 09, 2020AspirantMy router is connected to a little ISP modem. My Xbox is connected through a wired connection. All my other devices are connected by WiFi.
- Netduma-FraserDec 09, 2020NetDuma PartnerWhat XR500 firmware are you using? Have you disabled VLAN since and seen whether the downloads work properly?
