drjason
Oct 12, 2022Tutor
Nighthawk XR500
I've been having a similar problem with my XR500 running V2.3.2.134, the 2.4GHz channel just seems to turn off. The LED for 2.4GHz turns off, the remaining LEDs for power, internet, etc remain on. Th...
Oct 13, 2022Guru - Experienced User
How was FW updated on the router?
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
How many devices do you have all connected?
What kind of things are you doing when this happens?
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Is Smart Connect enabled?
Is 40Mhz coexistence only enabled?
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
- drjasonOct 14, 2022Tutor
Thank you for your questions. I think most of them are irrelevant other than the one about doing a factory reset.
The difficulty with diagnosing these problems is having a record of what was happening before the router stops responding, or having a watchdog that can power cycle the router when something goes wrong.- FURRYe38Oct 14, 2022Guru - Experienced User
Maybe however are important to help you find the problem and help us help you with what maybe happening. Not giving details doesn't help your cause. Reason why the forums are here and we are here as users to help each other out. At this point it could be anything. I would think you would want help to "find a solution". Power cycling the router every so often only masks the real problem. Routers should not need any reboots or power cycling frequently. IF they do, the problem needs to be figured out and solved.
- Netduma-FraserOct 14, 2022NetDuma PartnerIt would be easier if you could quickly grab the logs from the System Information page once 2.4GHz turns off - also try making a guest WiFi network for 2.4GHz, does that then also turn off when the main network does?
- drjasonOct 14, 2022TutorGrabbing the logs is part of the plan. A guest WiFi network is already created on the 2.4GHz network.
Still waiting for it to occur again...
