iamsotorious
Feb 20, 2019Aspirant
Nighthawk XR700 and AT&T Router IP Passthrough
Hello all.
I just recently switched to AT&T Fiber and i am using my router via ip passthrough. I have a small issue going on. When i connecto to the internet through my nighthawk XR700 i will g...
Feb 21, 2019Guru - Experienced User
What FW is currently loaded?
You'll need to contact the ISP and have them help you set up any IP pass thru that the ISP modem/router has. Might ask them if it has DMZ and you could use it's DMZ for the XR router.
Modem Combo Units:
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the NG router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the NG router gets from the modem. Or Configure IP pass thru if DMZ is not an option on the modem.
iamsotorious wrote:
Hello all.
I just recently switched to AT&T Fiber and i am using my router via ip passthrough. I have a small issue going on. When i connecto to the internet through my nighthawk XR700 i will get a packet drop that is siginificant enough to lag me in a game. When i take my router out of the AT&T modem / router, and plug straight into the AT&T router i do not experience this. Is there a possible setting that i am missing with th is pass through stuff that might be causing that.
Netduma-Fraser
Feb 21, 2019NetDuma Partner
Great suggestions above, I would see with the other options instead such as DMZ if you still experience the dropped packets.
Also were you using QoS/Geo-Filter at all?
