iamsotorious
Feb 21, 2019Aspirant
Nighthawk XR700 and AT&T Router IP Passthrough
Hello all.
I just recently switched to AT&T Fiber and i am using my router via ip passthrough. I have a small issue going on. When i connecto to the internet through my nighthawk XR700 i will g...
Feb 21, 2019Guru - Experienced User
What FW is currently loaded?
You'll need to contact the ISP and have them help you set up any IP pass thru that the ISP modem/router has. Might ask them if it has DMZ and you could use it's DMZ for the XR router.
Modem Combo Units:
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the NG router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the NG router gets from the modem. Or Configure IP pass thru if DMZ is not an option on the modem.
iamsotorious wrote:
Hello all.
I just recently switched to AT&T Fiber and i am using my router via ip passthrough. I have a small issue going on. When i connecto to the internet through my nighthawk XR700 i will get a packet drop that is siginificant enough to lag me in a game. When i take my router out of the AT&T modem / router, and plug straight into the AT&T router i do not experience this. Is there a possible setting that i am missing with th is pass through stuff that might be causing that.
iamsotorious
Feb 22, 2019Aspirant
Ok so i been running some tests with pingpliotter 5, and it is the Netgear router being an issue its the actual router losing a packet some how which closes the connection and causing my spikes. I ran multiple test, i ran straight from the at&t router which i played for an hour no problem, I then switched to my old apple router and it had no problem and came back to netgear router and getting those same packet drops. and i am beyond my return policy i had an issue early on with my router not achieving giabit speeds and i did the dumb mistake of not returning this router.
- FURRYe38Feb 22, 2019Guru - Experienced User
This will help us know what modem yoru using and how to direct you.
Modem Combo Units:
Couple of options,
- Netduma_JackFeb 22, 2019NetDuma Partner
- As Furry said, does your modem have bridge mode?
- Are you using the normal WAN port on the back of the XR700 to wire into the modem?
- Which firmware version are you on? You can find this by clicking the 'i' icon in the top right corner
- iamsotoriousFeb 22, 2019AspirantThe modem does not have a bridge mode feature. AT&T did help me setup the up pass through. The AT&T modem I do have is BGW210-700.
With all my test it it only Happens on the netgear I did get amazon to get me a return label thankfully.
