iamsotorious
Feb 20, 2019Aspirant
Nighthawk XR700 and AT&T Router IP Passthrough
Hello all.
I just recently switched to AT&T Fiber and i am using my router via ip passthrough. I have a small issue going on. When i connecto to the internet through my nighthawk XR700 i will g...
Netduma_Jack
Feb 22, 2019NetDuma Partner
- As Furry said, does your modem have bridge mode?
- Are you using the normal WAN port on the back of the XR700 to wire into the modem?
- Which firmware version are you on? You can find this by clicking the 'i' icon in the top right corner
iamsotorious
Feb 22, 2019Aspirant
The modem does not have a bridge mode feature. AT&T did help me setup the up pass through. The AT&T modem I do have is BGW210-700.
With all my test it it only Happens on the netgear I did get amazon to get me a return label thankfully.
- FURRYe38Feb 22, 2019Guru - Experienced User
It's recommended if your ISP supports a stand alone modem, to use this. ISP modems with built in routers cause problems for external routers connected behind them. Especially the ATT modem model.
Good Luck.
With all my test it it only Happens on the netgear I did get amazon to get me a return label thankfully.- iamsotoriousFeb 22, 2019Aspirant
Why is it that my apple router doesnt do that same hiccup?
- Netduma-FraserFeb 23, 2019NetDuma PartnerLet us know how you get on with your replacement router :)
