iamsotorious
Feb 20, 2019Aspirant
Nighthawk XR700 and AT&T Router IP Passthrough
Hello all.
I just recently switched to AT&T Fiber and i am using my router via ip passthrough. I have a small issue going on. When i connecto to the internet through my nighthawk XR700 i will g...
iamsotorious
Feb 23, 2019Aspirant
Mine works behind with IP Passthrough it just drops packets every 10 minutes. causing me to harder lock stutter in games.
Netduma-Fraser
Feb 24, 2019NetDuma Partner
Are you able to try without IP Passthrough to see if you get the same packet loss?
- FURRYe38Feb 24, 2019Guru - Experienced User
Also be sure to load up the first released FW version for the XR700. Others have reported having issues with more recent versions and going back to the initial first version fixed there issues.
- iamsotoriousFeb 24, 2019Aspirant
Mine only goes back 1 version out of the box does anyone know of a stable version?
Others have said that 1.0.0.20 worked for them...
