iamsotorious
Feb 21, 2019Aspirant
Nighthawk XR700 and AT&T Router IP Passthrough
Hello all.
I just recently switched to AT&T Fiber and i am using my router via ip passthrough. I have a small issue going on. When i connecto to the internet through my nighthawk XR700 i will g...
iamsotorious
Feb 25, 2019Aspirant
so after the downgrade it did get a lot better, the router still drops packets but not as significant as before, but the fact remains its still dropping out some how.
When previously before it would drop packet hard at the top and make a red line across all 3 and cause the hard stutter, this time it isnt hard stuttering and its only dropping at the router side.
Tomorrow i still have the rma for amazon im torn on what to do.
Feb 25, 2019Guru - Experienced User
You might return the unit and hold off a while until NG gets this corrected. Then come back and try another one. Just keep an eye on the download site for updates.
- Netduma-FraserFeb 26, 2019NetDuma PartnerThat plot looks really good to me, the packet loss looks very minimal. If it's not actually causing you a network issue then I would say that's normal. Sometimes packet loss happens but it's not always bad. A service or program could send more packets than is needed to ensure it gets to its destination and therefore some may get dropped along the way.
