Orangecar
Jul 31, 2020Follower
nighthawk XR700 can`t seem to connect
Hi, I have swapped my Plusnet router for Vigor 130 modem and the XR700. I connected them and all the relevent lights are lit, but when I try to set it up I get stuck at "trying to connect to interne...
Netduma-Fraser
Jul 31, 2020NetDuma Partner
Do you know if you require PPPoE or VLAN with Plusnet? Try and just go through the wizard without internet and then in Internet Setup change the settings that you may need such as PPPoE.
