MoonToast
Jun 01, 2021Aspirant
Nighthawk xr700, DumaOS not loaded yet
Hello, i have recently gotten this message since last Friday and i have tried rolling back the firmware and the other solutions for the XR500 and none have worked for this. I can not set up a wifi ...
MoonToast
Jun 02, 2021Aspirant
Hello, i have tried what you suggested and i have the same results. I have tried rolling the firmware back and that also didn't work.
I have tried multiple different browsers same results.
I have tried everything on the forums for similar issues of other devices and they too have not worked.
This seems to be a recurring problem for the xr routers.
What do you suggest i do?
Netduma-Fraser
Jun 02, 2021NetDuma Partner
Re-install the firmware using the TFTP method then factory reset after it's finished the upgrade (so 2 minutes after completion) then see if it works, may be the upgrade was corrupted.
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
- MoonToastJun 02, 2021AspirantHello, so i jave dont the TFTP flash. Started the setup and for some reason it has remembered our settings from before so i did a manual settings reset via routerlogin.net/adv_index.html
I then tried to set up the nighthawk as usual and i cleared my browser data/ cookies etc and reebooted and it says the same thing.- Netduma-FraserJun 02, 2021NetDuma PartnerThere is a guide at the bottom on how to turn on TFTP, follow that then go through the guide again https://www.howtogeek.com/250228/what-windows-10s-optional-features-do-and-how-to-turn-them-on-or-off/
- MoonToastJun 03, 2021AspirantHello, i am no idiot and i read that and did turn on the tftp client through programs and features yesterday then retried and these are the results that i explained yesterday.
Do you have a different solution?
