MoonToast
Jun 01, 2021Aspirant
Nighthawk xr700, DumaOS not loaded yet
Hello, i have recently gotten this message since last Friday and i have tried rolling back the firmware and the other solutions for the XR500 and none have worked for this. I can not set up a wifi ...
walhus
Aug 22, 2021Aspirant
DumaOS not loaded yet!
Don't worry we will redirect you shortly.
I get this message every time I attempt to update my xr700 router. I've tried a 30-30-30 reset dozens of times. I've tried to install every image, including the beta releases. I've submitted this to Level 3 support at Netgear but they haven't replied to me after 5 days. I've offered to send the router itself to Level 3. I purchased a Gearhead support contract. Nothing seems to work. I can get in to the router with routerlogin,net/adv_index.htm and it does support ethernet connections to the internet. Wifi fails. Does anyone have any suggestions as to how I can get past this impasse or get through to Level 3 at Netgear?
Netduma-Fraser
Aug 22, 2021NetDuma Partner
All that should be needed is a reboot from the interface - wait 2 minutes before accessing/connecting and then try and see if it works.
- walhusAug 22, 2021Aspirant
I've tried rebooting from the interface without success. I've spent hours on the phone to gearhead support. I'm now trying to TFTP all the images to the router. I get internet access from it but no DumaOS and no wifi. It's very frustrating. And I don't like giving up.
- walhusAug 22, 2021AspirantIt always fails with a frowning square face right after the "New Firmware Detected" screen. Right now current version V1.0.0.20 and it shows New Version V1.0.1.38 and I've tried choosing both options UPDATE and SKIP and the next screen is always the frowning square face. The url on this screen is routerlogin.net/BRS_index.htm
On the frowning squareface screen if you hover over it, it says:
www.netgear.com refused to connect
Then when you hit NEXT
it says, sadly
Don't worry we will redirect you soon
And then nothing happens and no other options are offered
I wonder if "Moontoast" here in this forum ever got back on track? I've gone through a very similar experience. This is EXTREMELY frustrating. I expect more from Netgear. I bought a gearhead support package but Netgear Level 3 has stonewalled me. I've been waiting for a week but not one word from them except that Level 2 support says they don't give out timeframes.
- Netduma-FraserAug 22, 2021NetDuma PartnerAre you accessing it via that link after every reset? If so just go to the usual URL/access using 192.168.1.1 and go through the wizard. If that doesn't work then judging by what you have done and given TFTP is usually a last resort I would say the router appears to be faulty.
